Cap'n Pete
- Joined
- May 17, 2016
- Messages
- 9
- Reaction score
- 0
Back when I was rigging my kayaks and canoes for early-morning and dusk/early evening excursions, I had always wanted to come up with a solution for the required navigation lights without filling my vessels full of yet more hardware, holes, wires, etc, but I never found any ideas I really liked enough to employ. Eventually, after searching through myriad battery-operated lights I came across a set on Amazon which fit the bill perfectly: Inexpensive, a lifetime warranty, and adaptable to almost any vessel needing a simple set of front navigation lights for those times you end up on the water as darkness takes over.
The holder is simply fashioned out of a short piece of 1/2" pvc with end caps. The lights themselves have built in straps which allow them to be wrapped to a cleat on the bow. Installation time is faster than it takes to get bit by the first mosquito after sundown, and they can be installed without modification to the boat, assuming you have a cleat somewhere near the bow. My light jumps from yak to canoe to boat in seconds, which I think is about as cost effective as one could hope for. Hopefully my idea can help solve the issue for someone else looking for an easy solution to this common project- Happy Boating!
