I said nothing about it being a "piece of junk".
Brand loyal perhaps?
Just pointed out what I personally didn't like about the 25hp ETEC that I have had experience with...and no it didn't have PT&T. Their LIGHTEST 25hp is 162 lbs as advertised. It's a 2 stroke engine. It's SUPPOSED to be lighter, but it's not. It's heavier than most of the modern 4 stroke 25hp models, thus IMO, outdated. It's a 2 stroke and "should" be less complex in it's design. It is...the basic ENGINE is, but we're not considering the numerous systems that are required to run the engine (specifically the fuel system components)-which are actually more complex than modern EFI 4 stroke stuff. On a 4 stroke, you're injecting fuel. On an ETEC, you're injecting fuel at higher pressures and also add oil injection...more complexity, more weight, one more thing to think about (have to add oil once in a while, and it's got to be specific oil in some cases). Speaking of which....I spent the entire weekend on the waterways in this area and didn't see a single ounce of ETEC specific oil...tells me that either they just don't keep it, or there's not too many ETEC's on the water in this area, OR they don't use much oil. Or a combination of one or more. I don't know. The weight turned me away from them. That among other things. One I used was smooth and pretty quiet but not the best looking, and the oil deal turned me away. I know about the re-flash....but with that reflash, is the engine still EPA certified 3 star? AND....price...the ETEC 25hp is what? $5500? Local dealer is discounting them severely ('16 models which are still new in crate) but couldn't tell me the price until I show up & do paperwork. Sounded shady to me but whatever.
10 year warranty? 3 years standard non-declining is what the warranty statement says. Didn't see anything about 10 years unless you buy extended warranty. Even then, you've got to stick to their service requirements...and document it 100%, if not, there goes your warranty. Might not be a big deal but it can be depending on who the owner is. Similar to Dodge pickups (that I know of...others may be similar)...yeah they've got warranty, but it's only "good" if you stick to the servicing requirements...and on the 2500 diesel, that service is not cheap. Brother's hemi pickup had an engine issue, and because he was "over" by 235 miles on a scheduled oil change, they denied the claim.
