groundshock
- Joined
- Apr 3, 2012
- Messages
- 20
- Reaction score
- 0
Just picked up a 1965 Evinrude 9.5 for my 1960ish Model AL Alumacraft. Being my first outboard (hell, first boat) I'm looking for any and all suggestions on what I should do to make sure that the motor is in tip-top shape, and any suggestions or tips on operation.
That said, I took it for it's first run tonight. Seemed good enough, but I guess I don't know what to expect. The boat hit 13mph on the GPS at full throttle with me (230 lbs), a full tank of gas (6 gal), electric trolling motor, and 27 series battery on board. Does that sound about right on a 14 ft boat? It never got anywhere near planing out on flat water, don't think I should expect that but it's worth mentioning. The battery and trolling motor were up in the bow, gas/motor/me obviously to the rear. I did my best to balance the weight out.
Also, I could get it down to about 2.2 mph at it's slowest, and it pretty much wants to die on anything lower than the 'shift' setting on the tiller handle. It's awfully shaky at lower RPM.
What type of performance should I expect out of it with the boat I have? Any guesses on what speeds I should be seeing high and low? Should the motor shut off when the tiller handle is put all the way to slow, or should I ideally have to hit the 'stop' button to turn it off?
Any insight on this would be great. Thanks guys.
