SAABologist
I have a 1989 Evinrude 8hp, model number E8RCEC.
I thought all the evinrude/johnson fuel line connectors to the motor were standard. I picked one up at the store, but the hole is too small to fit on the barb on the engine.
The connector on the motor is original. It has never been removed or replaced- the factory zip ties are in place.
The size of the metal ball and o-ring are the same, the only issue is the hole of the connector is too small for the barb on the motor.
The barb on the motor appears to be exactly 1/4" diameter as is the hole on the original connector I am trying to replace.
Does anyone know what's going on with the size of the Evinrude connectors?
Thanks much,
Thanks much,
