macawman
Think I'll do the break-in on the rebuild at 24:1 then maybe give 16:1 a try.
Most of your auto parts places have a can of oil/lubricant that we used to use for regular and roller tappet cams. We used to use them especially for start up on the old solid lifter cams to they got lubed up even when we pre-lubed them and primed the oil pumps. It was slick as two snails getting it on in a bucket. It you aren't comfortable using a good grade of motor oil prelubing the walls and rings/pistons I would get a can of that and use it.macawman said:Could use some advise on this. The book says the lube needs to be something that will handle the rigors of initial startup but will dissipate and wash out quickly so the oil can take over. That's definitely not STP.
I have found a source for OEM needle bearing grease. However the book makes frequent referenc to "1000" grease which I can't find. At least not by that name anyway. Anyone have any idea what they are talking about or where to get it?
macawman said:The book says to use "1000" sealant to glue the crankcase halves back together again. There is no gasket at that location. Anyone know why a hi-temp silicone sealant or form-a-gasket wouldn't work just as well?
