Cupping will typically let you run the motor HIGHER without blowout. But it also reduces RPM a little. 4 blades can also let you run higher.
A SS 4 blade 18p could be a good setup, will run REAL smooth, gets up on the 'pad' quick, and runs higher-if done properly, and the hull isn't too turbulent, may be able to run surface piercing. Most jon's won't allow it but you may be able to fudge the prop and get there.
"MOST" jons have a lot of hull drag as compared to a glass 'pad' hull, and that's where people get the wrong ideas...trying to make it run as fast as a high speed bass boat with the same HP. Sometimes it just won't happen, get into prop walk, cavitation, etc.
The 19P tempest wouldn't have been my choice but it's worth a try. Every hull every motor is different, but I doubt the RPM is going to change much if any. 5100 is real low if that's a light load. With a light load, I'd like to see it up around 6000-ish, maybe slightly over. Lugging (over-propping) a 4 stroke is not good.
There are 18P props made. I ran one on my old glass hull. 19P Tempest was WAY too much (lugged) and 17P wasn't enough. Found a Turbo that fit it in 18P which was right where I wanted it. 90hp Mariner (3 cyl) on a 15' Tide-crap. Topped out right at 59mph on that hull without much "tuning" (motor height).
If one prop is not enough RPM and the next available pitch is too much, you "can" have the smaller pitch cupped which sorta splits the difference. A good prop shop will guide you through it but you need to give them every inch of information that you can accurately get. GPS MPH, gearcase ratios, current pitch, etc. IF they just ask what pitch and what you want, find another shop. There's plenty out there, and there's 2 or 3 here that aren't worth the phone call time.
A customer of mine asked a similar question, 40hp yamaha 4 cylinder (2000 model F40 which is almost the same as an F50), one pitch too much, next available not enough. I suggested Ron Hill propeller and he called, sent it to them, got it back after a full blueprint and re-work for HIS setup, and he picked up 7 mph after raising the motor another 1/2", and better fuel economy, RPM right where it needs to be. That's impressive for a 40hp. No engine changes were made, although it's not hard to convert one of those to a 50. If that motor wasn't so heavy, I'd own one.
