Shadow Jr.
- Joined
- Oct 19, 2023
- Messages
- 18
- Reaction score
- 9
- LOCATION
- Colorado
Would 3m 5200 work ?For any type of filler to work, you need to put a nice chamfer/ taper around that hole. You could use a ball pein hammer to create a crater so the filler has surface to grab onto. Fillers won't hold onto the edge of a hole, it needs surface area. No, gluvit is to thin, you need a thicker filler to work.
Don't know if it can be sanded smooth after drying, haven't used that product, but many folks swear by it..Would 3m 5200 work ?
Why not put some filler in the holes and add a bolt in each hole with a rubber washer and a metal washer on both sides of the hole. Cut off the remaining overhang of the bolt and I doubt it will ever be an issue as a leak.
This! Those are decent size holes use a bolt that barely fits with a good washer and some filler.Why not put some filler in the holes and add a bolt in each hole with a rubber washer and a metal washer on both sides of the hole. Cut off the remaining overhang of the bolt and I doubt it will ever be an issue as a leak.
If this is the case, drop some solder into it, let cool and sand/file down.Unless I did not understand, the poster did not want to drill thru, the backing does not have a hole, whatever the material might be. At least there doesn't appear to be a thru hole. Correct me if I am wrong.....
Those holes were from a transom plate mounted on the exterior. I have recently replaced the transom board and repaired unwanted holes in the transom. I'm trying to repair the last two holes without drilling anymore holes in my transom board with JB marine weld epoxy. It seems to be staying in place really well. I will sand smooth and repaint with total boat aluminum paint. I'll keep my fingers crossed.I would most likely use a bolt with 5200 or epoxy as mentioned above. If you don't want to thru-drill or tap the hole, you could do the same with a screw. Or you could weld it, if it means enough to you.
I've done all three in various situations.
What were those holes for? A tow eye? If for a tow-eye, put another one back in. Those come in handy for various reasons.
