HOUSE said:I worked on the boat again after taking it out a few times. I replaced the front winch bolt with a new one from Academy.com that says it can support 2,000 pounds. I've been meaning to post pictures of it but keep forgetting to since I've been so busy modding my kayak.
Here's a picture of my kayak mods that have been stealing away all of my tinboat mod time!
It's a bass pro Ascend FS12 sit on top:
cvrx4 said:It looks like it is mounted underneath the cleat. Is there no issue with it being seen? I like the idea I just wanted to make sure it was good to go before mounting it there.
HOUSE said:Question: Once you pump a fuel line bulb so the air is gone, do your bulbs stay air-tight and "squeezed" in even after you kill the engine?
webrx said:if the bulb is "squeezed in" you need to check the tank vent and make sure it is open and air is able to flow.
d
17ft'r said:What kind of "software" did you use for the (animated) boat figure? :?:
Thanks, =D>
17ft'r
Gators5220 said:Looks like the tilt on the trailer is also a bit messed up, you can put a bolt through that if you don't want it to tilt, that's what I do for mine while on the road. Sorry to hear about the wench, which you will most likely have to replace, bummer.
If it's an aluminum boat and it's not worth trying to repair or sell, just haul it to any scrap metal yard or recycle business and you can pick up a few bucks for it. It should certainly bring you more $ than the gas it takes to haul it there.HOUSE said:I've been tempted to pick one up and swap trailers, I just don't know what I'd do with the POS boat that it comes with.
I've got to disagree with you on this. When oil burns in a combustion engine, it produces a white smoke with a very light blueish tint. That's the reason you see white smoke from the exhaust of all 2 cycle engines whether it's outboards or gas weed trimmers. If in doubt, get your lawnmower running and drop a few drops of oil down the carb. Constant black smoke while running from a combustion engine is a sign that it's running too rich. If it only produces the black smoke at startup, it was slightly flooded.Gators5220 said:White smoke is gas, make sure you don't choke except for one pull, just word to the wise, white gas, black oil.
