bcbouy said:i went to a storage place,bought the biggest box they had,opened it up and layed it across the top of my boat and traced the hull shape from underneath then cut out the shape and sliced the template down the middle and slid it together to fit the shape of my boat and trimmed it down.it fit perfectly to within a quarter inch to account for carpet thickness.i had to trace the template over 2 2x8 plywood sheets because my boat is too wide so my deck is actually 2 sheets butted together.it made it easy to make the center hatches though.
[url=https://www.tinboats.net/forum/viewtopic.php?p=315186#p315186 said:Captain Ahab » 18 May 2013, 15:42[/url]"]If you can - make your deck 2 pieces joined in the center (bow to stern) - do the same with a cardboard template and use a razor knife to cut the angle on the cardboard - this way you can always adjust for width from the straight edge down the center.
Remember to leave a little and then just use a sander to work out that last little bit - we used an angle grinder with a sanding disk to make small "adjustments" until everything was tight.
If you plan to add carpet you can hide any "misses" with that - you can also add an aluminum carpet trim piece to cover any gaps
