2sac
2013 Lund 2010 Predator w/225 ProXS 60gps
You've got a 2010 Predator?!?!? ](*,)[url=https://www.tinboats.net/forum/viewtopic.php?p=319390#p319390 said:2sac » Today, 13:57[/url]"]2013 Lund 2010 Predator w/225 ProXS 60gps
That's what it says on the side[url=https://www.tinboats.net/forum/viewtopic.php?p=319411#p319411 said:RivRunR » Today, 15:43[/url]"]You've got a 2010 Predator?!?!? ](*,)[url=https://www.tinboats.net/forum/viewtopic.php?p=319390#p319390 said:2sac » Today, 13:57[/url]"]2013 Lund 2010 Predator w/225 ProXS 60gps
:mrgreen: My dream boat. *sigh*[url=https://www.tinboats.net/forum/viewtopic.php?p=319446#p319446 said:2sac » Yesterday, 23:48[/url]"]That's what it says on the side[url=https://www.tinboats.net/forum/viewtopic.php?p=319411#p319411 said:RivRunR » Today, 15:43[/url]"]You've got a 2010 Predator?!?!? ](*,)[url=https://www.tinboats.net/forum/viewtopic.php?p=319390#p319390 said:2sac » Today, 13:57[/url]"]2013 Lund 2010 Predator w/225 ProXS 60gps
Upgraded from a 17ft Mirrocraft
I researched new boats for almost 3 years before I finally decided on the Predator. Couldn't be happier. Only complaints I have is if the wind catches the back end while on the TM the stern tries to catch up with the bow. (The bow is a deep v and the stern is a modified v which just sits on top of the water.) It doesn't have a cooler(I'm using the stern livewell) Also should have got the 101lb thrust TM instead of the 80. Not as fast as most of the 'glass bass boats I fish against, but it handles rough water like a dream. The 225 ProXS is better on fuel and oil than the 90 ELPTO I had on the Mirrocraft. The bow livewell with the dividers is great for culling bass. A ton of storage and a ton of front deck. Casting with more than 3 people ain't gonna happen, but that's true on most 20 footers. Still need to install a Hot Foot and a MercMonitor.[url=https://www.tinboats.net/forum/viewtopic.php?p=319390#p319390 said:2sac » Today, 13:57[/url]"]2013 Lund 2010 Predator w/225 ProXS 60gps
Although I'm still in the learning curve, I really like the Link. The "spot-lock" is just ok, it can travel up to 5' from the anchor point, and since it doesn't maintain boat orientation, it's not hugely effective for holding on a spot to fish (especially with wind)...but for changing out baits, or taking fish off the hook, etc it works. The iTrack features of being able to record a track and then auto-navigate it (start to end, or end to start) are great. If you're in big wind or current it's not as effective, but it's pretty handy otherwise. I don't have the follow-map-contour features because Lakemaster doesn't have maps to cover my area. My only real complaint so far is that the remote's keys are not backlit, so they are hard to use in the dark...but I painted them with glow-in-the-dark paint which helps. Being able to use navigation features from the HB unit on the console also comes in handy too.[url=https://www.tinboats.net/forum/viewtopic.php?p=319473#p319473 said:2sac » Today, 08:50[/url]"]I researched new boats for almost 3 years before I finally decided on the Predator. Couldn't be happier. Only complaints I have is if the wind catches the back end while on the TM the stern tries to catch up with the bow. (The bow is a deep v and the stern is a modified v which just sits on top of the water.) It doesn't have a cooler(I'm using the stern livewell) Also should have got the 101lb thrust TM instead of the 80. Not as fast as most of the 'glass bass boats I fish against, but it handles rough water like a dream. The 225 ProXS is better on fuel and oil than the 90 ELPTO I had on the Mirrocraft. The bow livewell with the dividers is great for culling bass. A ton of storage and a ton of front deck. Casting with more than 3 people ain't gonna happen, but that's true on most 20 footers. Still need to install a Hot Foot and a MercMonitor.[url=https://www.tinboats.net/forum/viewtopic.php?p=319390#p319390 said:2sac » Today, 13:57[/url]"]2013 Lund 2010 Predator w/225 ProXS 60gps
How do you like the iPilot Link?
I've got the Terrova iPilot and I'm interested in the follow the contour. It's another $700 to add the iLink. :shock:[url=https://www.tinboats.net/forum/viewtopic.php?p=319499#p319499 said:RivRunR » Today, 09:42[/url]"]Although I'm still in the learning curve, I really like the Link. The "spot-lock" is just ok, it can travel up to 5' from the anchor point, and since it doesn't maintain boat orientation, it's not hugely effective for holding on a spot to fish (especially with wind)...but for changing out baits, or taking fish off the hook, etc it works. The iTrack features of being able to record a track and then auto-navigate it (start to end, or end to start) are great. If you're in big wind or current it's not as effective, but it's pretty handy otherwise. I don't have the follow-map-contour features because Lakemaster doesn't have maps to cover my area. My only real complaint so far is that the remote's keys are not backlit, so they are hard to use in the dark...but I painted them with glow-in-the-dark paint which helps. Being able to use navigation features from the HB unit on the console also comes in handy too.[url=https://www.tinboats.net/forum/viewtopic.php?p=319473#p319473 said:2sac » Today, 08:50[/url]"]I researched new boats for almost 3 years before I finally decided on the Predator. Couldn't be happier. Only complaints I have is if the wind catches the back end while on the TM the stern tries to catch up with the bow. (The bow is a deep v and the stern is a modified v which just sits on top of the water.) It doesn't have a cooler(I'm using the stern livewell) Also should have got the 101lb thrust TM instead of the 80. Not as fast as most of the 'glass bass boats I fish against, but it handles rough water like a dream. The 225 ProXS is better on fuel and oil than the 90 ELPTO I had on the Mirrocraft. The bow livewell with the dividers is great for culling bass. A ton of storage and a ton of front deck. Casting with more than 3 people ain't gonna happen, but that's true on most 20 footers. Still need to install a Hot Foot and a MercMonitor.[url=https://www.tinboats.net/forum/viewtopic.php?p=319390#p319390 said:2sac » Today, 13:57[/url]"]2013 Lund 2010 Predator w/225 ProXS 60gps
Same here, but I stick to 6 inches. There's a thread in jet boats explaining why I don't go in 4" anymore...[url=https://www.tinboats.net/forum/viewtopic.php?p=319480#p319480 said:RiverBottomOutdoors » Today, 09:00[/url]"]Mine will do 27mph in 4 inches of water.
