scubapro820 said:
That thing was neat!! when I get a chance i will draft my idea for this project.... although at the moment im in the process of building a new house so I wont be able to afford to build it anytime soon. iva actually been thinking of doing more to the boat I have now Im not happy with 38-42mph anymore I think ive come up with some ideas to achieve 50mph
1 aluminum tigershark 900 engine mounting bracket vs the 45lb 3/8'' thick steel plate one
I never compared the weight between the steel mounting plate and the aluminum one, but the 2 were interchangeable between the 900 and the 1000, the motor mount holes are in the same positions, and the holes in the plate that bolt it to the engine are exactly the same. I do know that the aluminum plate is quite heavy and thick, though, but I'm not sure about its exact weight.
3 the stupid half arsed engine box I made bc I was broke is made of wood will be replaced with an aluminum compartment
It'll be more durable, and lighter in weight. If you form it by braking, the bends will give added strength. If not, then using some aluminum angle welded to the inside will help stiffen the structure.
4 reduce pilot house profile be 12''
This will make a difference. I have a T-top that I use on my jetboat in cold weather, it has a full-height windshield, as well as side window panels, there is at least a 2-3 MPH difference in the top end when compared to the standard-height windshield I usually have on the boat (4 bolts is all it takes to switch out)
These are older photos, as the sponsons are on the boat, taken back around 2006, about a year after the boat was built.
5 send impeller to impros for a custom pitch still have the top 1/4 of my throttle that just gives me 7800 rpm with no speed increase
Experimenting with pitch can either give good results, or crappy ones.
Another option you should consider is a "Wet Wolf Adjust-A-Thrust Nozzle" It uses a spring loaded shuttle that responds to varying water flow through the pump, and it can give top end gains of around 1.5 MPH, as well as better hook-up and loading in choppy water. I started running one on my boat a few months ago, it does make a difference. Better hole shot, better top end, and better hook-up in the chop.
6 mess with the water pickup design
You mean the intake duct? I may have already asked this (I suffer from C.R.S. sometimes) but, have you tried a top-loader grate? If so, you may be able to experiment with the rake angle of the top loader scoop on that grate where it's not so steep, which should remove some drag.
You could possibly cut the rake loose from the longitudinal tines, using a thin-kerf recipro saw blade, then, drill a hole through either tine, for a screw, and then drill and tap into the sides of the rake/blade itself.
This way, you could position it, and lock it down, and experiment with varying angles, without having to cut and re-weld it every time. Once you're satisfied with the position, then weld it.
if that doesnt get me 50 im switching from a skat trak swirl to a straight cut design for top end I think that the swirl costs me 3+ mph
I can ditch 100lbs and alot of wind resistance I think what do you guys think?
I think you're on the right track. Not sure about straight cut vs. swirl impeller as far as top end. I do know that swirl impellers are better in rough water, and they're less susceptible to being fouled than straight blade impellers. But as far as which one gives better top end, I'm thinking probably the straight edge.
