=D>WhiteMoose said:Got it done. 8) Contrary to what the service manual and every other video and piece of literature I've seen said, there is no shift shaft coupler on this motor. The shift rod is one piece, all the way to where it hooks into the stupid little plastic clip behind the carburetor. Getting a screwdriver into that little space to undo the clip was horrible. The actual water pump was a piece of cake once I got it all off. Then getting the clip hooked up again was a bear. There is a pin in the clip you have to line up and insert through the shift rod, then into the other side of the clip, all while using needle nose pliers and keeping the screw holes aligned.
Anyway, its done. It took awhile, but I started the motor for the first time in 20 years. Let it run for about 20 minutes on a strong mix of seafoam, and everything seemed to be in order. Thank you guys for all the tips.
