IndyWingmaster's Duck/Bowfish Combo 14' V
Indianapolis, IN
Hey everyone, I just joined the site a couple days ago. I am getting around to getting pictures of my boat in its current state. It has been so miserable here Indianpolis that I really don't care to pull it out to take some pictures. My Boat is a 1976 Alumnacraft 14' Deep V. I am working on getting a motor some time soon. Probably around a 25 hp. outboard. I have an idea for how I want the finished product to look, but I think I don't have the know how to get it there. My usual motto is "wing it", but I see that not being the best of ideas. I want to build a raised deck just under the side railing of the boat. With this elevated floor I am going to have to do some framing. I am not carpeting the boat, but will probably put down a non skid material for the surface, linex, herculiner, Cabelas non skid, etc. I have several questions that I need your help with before I start this build.
Framing - I read on another post in here about using galvanized brackets and attaching them to metal saying that is a bad idea due to chemical reaction between the aluminum and the galvanized steel. Any thoughts?
Also, I have a friend that is going to be helping me on this rebuild and he is wanting to weld square tubing for the frame. So framing using steel instead of wood. Which I see several of you using wood in here and I don't know if its because it is cheaper, wood is better, etc. Wood vs. steel?
Floor covering - I mentioned earlier about non-skid material for the flooring. What is a good material to use, but still reasonably affordable? Although probably not my cheapest option I am leaning towards linex. I have another friend that put it on his boat and it definitely meets my standards for durability.
Transom -I am going to probably rebuild the transom. The wood on there currenty looks kind of rough. Being that I feel the transom is very important I am looking for advice or helping me find some other posts where you guys rebuild the transom.
I am going to have to seal the edge of the boat where the new floor meets up with the aluminum siding of the boat.
I will post pictures as soon as I get them, possibly later today, if not it will be on the weekend. Thanks in advance!
Here are the photos of my boat. The only things I have previously done to this boat is the light wiring, floorboards, and removed the third bench seat (still have it).
    947.9 KB
    973 KB
    946.9 KB
    933.6 KB
    969.1 KB
    964.3 KB
    936 KB
    930.5 KB
    944.7 KB
    983.3 KB
    961.3 KB
welcome aboard! i think the setup you have on your hands is pretty much a clean slate and has very much potential. i own a 14 ft sea nymph deep v and im decking it with plywood and bracing it with 2x3's and they do exactly what i want them to do. i guess it all boils down to weight. if you are worried about how much it is going to weigh i would go with aluminum. if you are leaning more toward strength i would defiantly go with wood. happy building!!!!!!!
Well, now that you mention weight I do have concerns. Mostly due to the fact that my boat doesn't have maximum capacity ratings on it at all. They weren't on it when I bought it. Not sure what to do about it. Anybody have any thoughts?
I just found out that one of my friends can weld aluminum so he is helping me out with that. So now I have an option of either wood or aluminum framing.
well from the size of your boat i probably wouldn't worry about weight. having the aluminum welder friend is a plus because it gives you an either/or option. i could only do wood because my dad and i have absolutely no experience in welding of any kind so we could only use wood. luckily my dad is an excellent craftsman. :D i guess now it comes to money. do you have very much expendable cash for this build? if so i would jump to aluminum in a tenth of a second.
I am using a blind for mine right now. Are you going to have flip up blind doors? See you shortly so you can look at what I did on my boat. If I had the skill, I would have gone aluminum. I am sick of sealing wood!
Bob
Well as far as the budget goes I am not sure yet. I would like to see it as least expensive as possible, but still not sure. I went today and looked at nkhrfh and realized that I need to account for any electrical now before I get too crazy. I saw his on board battery charger and how he had it set up and decided that I would really like to put one in my boat. I need to also think about wiring for my lights for bowfishing.
