the XPS boards (blue, pink, or green insulation boards) that most people on here are using today are the same material as styrofoam (they are both polystyrene); it's just a different manufacturing method (extrusion) which results in a solid piece rather than the little foam beads. either can dissolve if exposed to gasoline, so just try to avoid pouring gasoline down in the bilge.surfman said:The problem with styrofoam is that if it gets any gas on it, it just disappears, and dissolves away, there are better alternatives out there today. (styrene foam, Styrofoam is actually a trade name I believe)
minuteman62-64 said:After doing some more reading on mill scale I'm thinking I may have a project for this winter. Appreciate if you'd keep us up to date on your progress.
sonicwonder2000 said:Got some phosphoric acid etch and supplies at the Home Creapo today ... going to have a hand at removing the milscale tomorrow...
BTW, galvanic corrosion can occur whenever there is a potential (voltage) difference between the hull and ground, and there is an electrolyte (conductor) between the hull and ground. Thus - if you have a battery connected to the hull (electric start Mercury motor), and an electrolyte to ground (wet, salt-soaked bunks), galvanic corrosion can occur. #-o
minuteman62-64 said:What was the name of the stuff you got at Home Depot? In paint dept.?
Still wrestling with the corrosion issue w/batter hooked up in boat (actually, I'm lazy and looking for a rationale to not un-hook the battery every time I put the boat back on the trailer). The (limited as it may be) reading I've done on galvanic corrosion indicates that, like electrolysis, two different metals in solution are operative. Also, appears in the situation you describe, there'd be a current flow between the hull (at the -12V potential) through the carpet and the wood bunks to the metal of the trailer and to the ground. Isn't a return current flow to the battery necessary to have this occur? Otherwise, seems like I could discharge my battery by hooking up the "-" terminal to a rod driven into the ground.
PSG-1 said:As for eliminating the current while the boat is trailered, use a battery disconnect switch. That will also eliminate any battery drain caused by any devices in your boat that may pull small amounts of current.
