CedarRiverScooter
- Joined
- Nov 13, 2014
- Messages
- 1,522
- Reaction score
- 6
Be sure to support motor when trailering. The highway bounce will also stress the jack plate mounting bolts.
C&K said:A rooster tail is normally caused by trimming up so the prop shaft is not parallel with the water flow. The tips of the blades throw the water and create the rooster tail. I can't see that being the case with a 15hp motor.
It sounds more like you got something merely plowing the water and directing it straight up as it comes off the hull. I don't know what that would be - a transom-mounted transducer maybe?
C&K said:Well, 8hp probably wasn't enough to get the boat on plane or get any speed. 15hp isn't enough to have the prop throw any significant rooster tail even if it was trimmed way up and ventilating the prop. So what I was thinking was, now that you're going faster and maybe getting the transducer up on the pad it's simply catching the water and making it spray upward. You should be able to look and see what's making the rooster tail.
Rookie1719 said:C&K said:Well, 8hp probably wasn't enough to get the boat on plane or get any speed. 15hp isn't enough to have the prop throw any significant rooster tail even if it was trimmed way up and ventilating the prop. So what I was thinking was, now that you're going faster and maybe getting the transducer up on the pad it's simply catching the water and making it spray upward. You should be able to look and see what's making the rooster tail.
I played around within the trim and engine height. Last night had no significant tail like the other day - minus the transducer but it was small.
Working smooth
C&K said:While I am a firm believer in jack plates to trim the boat out, unfortunately in your case, 6" is too much. It will place the point of thrust on the transom too high. A jack plate is a lever……
C&K said:I'd like to point out that modifying the transom is no better option than a jackplate or riser. With the wrong outboard for that hull, the thrust angle will never be right without using an extreme trim position. Whether you modify the transom or use a jackplate, the hull was never designed for that at an extreme of using the wrong length shaft on your outboard. There is a reason the boat came with a 16" transom.
Again, I am a firm believer in jackplates that allow adjusting the thrust height without changing the thrust angle. But this is a performance adjustment to get a few more mph out of the boat that usually involves changing the height no more than 1 or 2" to ventilate the prop and get the engine to peak hp with a big pitch prop. Or adjusting the height for shallow water operation without changing the trim angle. This is not the application for that.
clarkbre said:I do have to ask C&K, my boat is a Lund WC16 that comes in both a tall 20” and short 15” transom.
eeshaw said:clarkbre, on that riser you had constructed, how thick are those pieces that straddle the transom on each side? Also, how big are the bolts that attach it to the transom?
C&K said:clarkbre said:I do have to ask C&K, my boat is a Lund WC16 that comes in both a tall 20” and short 15” transom.
Jackplates are a simple problem of mathematical vectors and lever forces. The thrust is developed at the prop. But the force is transferred to the boat at the point of attachment of the outboard. The longer that lever, the higher the twisting forces are on the transom. While you can get by with this as shown in your photos with 15 and 25hp outboards, try it with a 150, 200 or 250 on a bass boat. You'll break the transom.
Sinkingfast said:A crap load of hi hp bass boats use movable jack plates.
That's what I figured you'd had done. That should be fine for a small engine. I think the only thing I'd have done differently than what you did was to put a radius in the two corners of the cutout that straddles the knee. Thanks for the reply to the question.clarkbre said:eeshaw said:clarkbre, on that riser you had constructed, how thick are those pieces that straddle the transom on each side? Also, how big are the bolts that attach it to the transom?
The front and rear plates are 1/8" thick and sandwich 4 pieces of 1 1/2" tube aluminum stacked and welded.
To secure it to the transom, the 1/8" plates are through-bolted with (4) 3/8" bolts that are 5" down from the top of the original transom.
The motor that mounts to it is a 15hp Suzuki 2 stroke that has a dry weight of approximately 90 lbs. Mounted on the riser, there is absolutely no flex or wiggle. It is a very stout piece.
I think the key to the strength is in the low through bolts. I looked at the pre-made jack plates but didn't like that they only bolted to the rear of the transom. I designed mine to carry the load to both the front and rear as to not peel off the rear.
The through bolts 5" down from the top of the transom.
The front is also supported by the boat's center brace that ties into the floor and transom.
