A prop boat just can't get to those areas and most heavier O/B jets ground out when they come off plane (truly something that has to be seen to believe). I can run over the interesting stuff and float back through it. I can feel the hull lift when I'm close to the bottom from the compression effect, feels almost like a roller coaster ride at times.
Having a jetboat that weighs about 1100-1200 lbs, I can speak from experience about grounding out, trying to run in water that's just too shallow. Only had it happen twice, which is a pretty good record for some of the water I've run in. Needless to say, it's a quick stop when it happens! :shock:
The shallow water cushion effect is a pretty neat thing to experience, when the boat hits deeper water, you can feel it squat, and when it crosses a shoal, it flattens out and begins to lift.
On another note about shallow water cushion, another neat effect is when you are in a shallow area, particularly a narrow area, like a ditch or small creek. You will get bank cushion on the bow, where the boat is pushing water ahead, and it causes the bow to veer away from the bank, while at the same time, water is being pushed from behind the boat and then rapidly filling back in, which causes a bank suction, drawing the stern into the bank.
What's really cool is making a boat do a reverse "wheelie". This is done with a regular prop drive, going in reverse in a shallow ditch. Works real good for guys like me that have to go through a narrow channel to get to the dock. Starting with the motor trimmed up, as you give it throttle, it begins to pull water under the transom, which raises it up. If done correctly, it will raise the transom so much that you have to trim the engine down more to keep the prop from sucking air. Using more throttle, you can bring the transom up high enough that you have to trim all the way down. This rapid pull of water under the transom causes the bow to squat, and as the water passes under the boat and fills in the void, it creates a standing wave behind the bow, as the boat moves along in reverse. Since the transom is the heaviest part of the boat, creating this lift effect picks it up, and drags the lighter bow end behind, which will allow you to go through water so shallow that you could never attempt to do it going forward. But don't back off the throttle until you begin to trim up, or it's a sudden stop that could damage your lower unit.
