irishpride42
Actually spelled luaun, but anyhow, how would it work for flooring? It is 1/2" thick.
hyzerbomber said:not sure if it is the same thing, but found this.https://www.onlinetips.org/luan-plywood-subfloor. you may want to reconsider.
bobberboy said:hyzerbomber said:not sure if it is the same thing, but found this.https://www.onlinetips.org/luan-plywood-subfloor. you may want to reconsider.
I have to disagree. First, luan comes in several thicknesses over 1/4". I have used 1/2" at work for almost two decades. Second, trees grown in tropical or high moisture conditions are less susceptible to moisture damage, not more. Redwood, cypress, teak and mahogany are all woods grown in wet or tropical conditions and all are very resistant to water. I don't know who authored that article but it's very misleading.
Quackrstackr said:Just an fyi.... Thompson's will probably last less than a year if the boat sees any kind of constant exposure to the elements.
