Lithium Battery Question - 50AH LiFeP04 for a 55# thrust Minn Kota?
Looks like Wieze has a dual purpose now, looks interesting to me since Id prefer just one battery and really only use it for TM and starting.
I still wouldn't run one for cranking untill either my warranty is up or yamaha says they are OK. I think the biggest problem is charge profile from the alternator
Ahh yes, forgot about that issue! Probably will need two batteries then. Suzuki I plan to get recommends only Lead Acid. Also just read the stator from the Suzuki might not be able to charge the lithium battery either...
I suspect now that these are more common and more people are using them that outboard manufacturers will deal with that on their end pretty soon. I'd love to go all lifepo4 I could save another 100lbs.
A high quality lithium starter battery won’t damage the alternator. However, the alternator will never fully charge a lithium battery. So top the battery off when you get home with a proper charger. They do work quite well, at least my Noco starter battery has. Whether it’s worth it for your application is really your call. I would not try this with an el’cheapo lithium starter battery.
I’m Ok with it for small boats but, I’ll stick to lead acid for the bigger outboards that can’t be easily started by hand.
Last fall, up until two weeks ago I also went with cheaper brands 50ah for my 93sv and HB5 sonar/gps on the 12ft.Jon Topper (1) wgt savings installed in middle seat (2) images appear to be cleaner I kept the 31 series for TM and moved it to the front of third seat in the stearn, balances out very well. Now, the PT185 has100ah (2) for 75# 24v olStearns, (soon to be a Proguide Tour or basic Power Drive..waiting on a sale) 50ah for house sticking with 27series AGM starter for the 90hp again weight savings! NOCO 10x2 and Suuwer 5A keeps everything going.
According to a friend that works for a battery mage in our area, they are working on a device that uses the charge from the motors generator/ alternator to charge other batteries ( not Lithium) and just uses the lithium to start, no charging off the motor. The charging device on the motor is not healthy for the lithium battery either. Small engines have never been a problem using lithium type batteries for starting, the issues are charging that type. Now...your big block high compression engine starter is a different story, to much big amp draw hit to the starter is not healthy for the battery. They will get better as we learn more but for now, be cautious on how you use them and do not experiment, I have saw first hand what an improperly used lithium can do and it ain't pretty !!
At $400, it's expensive for a 60AH battery.
My 100AH TimeUSB starts my Johnson 60 easily, but I've only used it when my starter batter decided to die without warning.
I'm sure they can easily make a voltage regulator/rectifier to work with LiFeP04 batteries. It would just need to be set to charge a couple of V higher.
They make a trolling motor battery charging system that works off your engine. In theory, that would be easily modified for lithium.
I suspect that they are just metering out products as slowly as possible to maximize profits, but maybe I'm wrong...
My guess would be that the boat motor mfgs don't want to bet on LiFePO4 starting batteries to change to an alternator that supports them, yet. With the sub-zero temps, would still be problematic for cars/trucks. If it happened there, it would trickle down to boat motors. Boat mfgs and dealers, still like to use the lower cost LA to keep the pkg price down. They don't care that the battery will only last a few years.
