I’m restoring my new to me 14’ Sylvan. It came with a split seat instead of a middle bench, and the left hand side was removed at some point. From what I can find out a live well was an option but I don’t think this had a factory one. There is an over flow fitting that was installed but it has the look of an owner modification. It’s through the hull about 8” in back of the seat. There is no live well now though.
Anyway my dilemma is whether to just put in a seat with some storage or try to fabricate up a live well. This is my first boat in 40 years and I’m just starting to get into fishing. Is a built-in live well worth the trouble, or should I just stick to storage? It would only be 8-9 gallons.
It strikes me that it would be cleaner to run any tubing now while I have the floor up. Also If I do put in a live well I would move the overflow so that the thru the hull fitting would be under the seat. If anyone has a similar set up I would appreciate some pictures. What did you use for a tank?
Thanks
Thanks
