I have a 2003 tracker v14 superguide with a 25hp. I only fish the lake that I live on, mostly because all of the surrounding lakes have a 10hp limit.. my lake has unlimited hp, so there are usually 10-12 jetski's flying around and half a dozen people skiing during the day. I usually go out at dusk, while the whole lake is no wake. i rarely use the 25hp. i put in 3 gals each year, and usually have enough left over to run my chainsaw in the fall :shock:
it is a console boat and needs recarpeted. I was never happy with the layout, as I troll mostly. I am wanting to convert it to a tiller steer, which is simple in the boat, because it looks like the console and other pieces that go along with it, were added to a tiller boat.
since I mostly troll, I thought a 6hp tohatsu would be a good choice. I want an engine with a built in tank, and the 6hp is the largest that I have seen
the boat is heavy, .100 aluminum and a lot of 3/4" plywood decking. id say it weighs 6-700lbs.
sorry,a little long winded. my question is, does anyone else have a large deep v with a small outboard? if so, do you have any tips on prop pitch, etc?
I really like the stability of the boat. it is 74" wide and easy to walk around in (even better, once i remove the console)
