Making a Portable Live Well
Thank you all for the information and a big thanks to Perchin for your input.. I finished the cooler and now hooking up the wires and the switches and it will be done! So thanks everyone!
Denis
Well I finished the livewell and I used some things that is not conventional to the rest of yours! I have a pump that circulates the water and I'm using a washing machine hose for the water connections! I lost the bottom of the pump and had to use something or go out and spend more money! I drilled the side of the cooler and then drilled out the drain plug area! Mounted a bilge pump inside of the cooler to drain the water out! I have 2 electric switches for the pumps and drilled 2 holes in the hull of the boat! I have 2 shut off valves and that is about it!
Thanks to you all for the help, And Perchin for his design helped a lot!
Dennis
