wmk0002
Bowhunter1661 said:Yes sir, already have one. My idle speed prior to making linkage adjustments was 650-700. I thought it was idling low due to being rich and subsiquently misfiring. But now I think it was misfiring due to the low idle. There was fuel bubbling up from under the water when it would diewmk0002 said:It may help you to buy a knock off tiny tach from Ebay or Amazon. You can get them for about $15. It will help you get it to the factory recommended forward idle speed (in tank or water) plus give you your WOT rpm's just in case you need to re-prop it.
Oh, I see. What are the forward idle specs for your motor? I think most magneto ignitions recommend 550-600 rpms while CDI ignitions are approximately 750 rpms. I would think your 650-700 would be fine.
