You can buy it at home depot, It is floor polyeurathane, Oil base.....with clear over it. It is pretty reasonable 24-26 bucks a gallon and is no different than paint. I rolled it on. I am getting close to a water trial but still a few weeks out. I have everything to finish the mod, with the exception of trailer parts. I had them tint mine to the darkest grey I could get.....They do have it in white.Jonboat Jerry said:That deck looks great. What are you using and does it come in white?
Nice work, do you have any pics of the boat on the water? =D>
bigwave said:Just ask the guys at the paint counter at home depot. They are pvc plastic flakes. I put one coat of the floor paint on first and let dry for a day. Then I put a second coat on and used my hand to randomly scatter on the surface of the wet paint. Once it dried I followed with a clear coat of polyeurathane for the finish coat. It is very easy and they have three or four different chip colors. You can even have the floor paint tinted with a wide color range. I chose light grey since I live in Florida and the summer sun would fry you and your feet if the floor was a dark color.
Yes it is similar. I think it will be fine for the life of the wood. Next time the deck will be welded and sheet aluminum for the floors. I have one of the side lockers roughed in and it will be painted the same color as the decks. The glidden brand is only $25 a gallon, that fits my budget right now. Next time I will use Pettit easypoxy for the aluminum.PSG-1 said:bigwave said:Just ask the guys at the paint counter at home depot. They are pvc plastic flakes. I put one coat of the floor paint on first and let dry for a day. Then I put a second coat on and used my hand to randomly scatter on the surface of the wet paint. Once it dried I followed with a clear coat of polyeurathane for the finish coat. It is very easy and they have three or four different chip colors. You can even have the floor paint tinted with a wide color range. I chose light grey since I live in Florida and the summer sun would fry you and your feet if the floor was a dark color.
I'm guessing the paint you used is probably similar to the Behr Garage Floor Paint.
Good stuff, I used it to do the floors of my shop. Almost time to have to do it again, though. Of course, my shop floor gets WAY more abuse in the course of a month, than your boat will ever see in its lifetime. :shock:
