Justaguy442
- Joined
- Feb 8, 2019
- Messages
- 33
- Reaction score
- 0
A transom saver takes zero weight off your transom, all it does is stop your engine from dropping down when its raised and stop it from bouncing which can flex your transom. A motor that down can be subjected to rocks ect bouncing off it when going down gravel roads. I hang my 15 hp straight down the transom takes no more abuse then when it's on the water. On my 115 I use a transom saver because if my motor was to drop it would hit the pavement. I'd say only time to travel with a raised motor is if you dont have the ground clearance when in the lowered position.
