JonBoatfever
I found a shear pin in the bottom of the bucket. Could this missing be causing the loud noise? HELP also , where does it go back in the motor?
fool4fish1226 said:JBF Have you posted your motor issues in the engine section
John Wasmuth said:Might try pulling and cleaning the plugs. Clean the fuel filter or replace it if it is really clogged up. Pull the carb, tera it down and clean it. Also check for junk in the gas can.
trueblue1970 said:Hey nice job on your boat...be proud of that. Did you notch the sides of the floor?
