jigngrub
fool4fish1226 said:I know one thing for sure about two part pour foam, I sticks to your skin like theres no tomorrow. :LOL2:
Loik this?
https://www.youtube.com/watch?v=zAIY0I5GGw4
FuzzyGrub said:I have seen bad pour in foam work in both alum and fiberglass boats. It is not unusual to see the main drain channels plugged. While JnG's are clear, the pictures don't show how water would drain toward the center, from the sides. Some mfgs must think that water will never get in there. Water will always find a way!![]()
skinnywaters said:Agreed. Remember that a v hull boat obviously drains different than a flat bottom. The two outside channels that run the length of the floor, run directly into the foam boxes. The foam sits on the floor thus trapping the water. My boat is a 1988 Lowe husky boat, this is the first problem I have ever had with the hull
skinnywaters said:Thanks for the tips on paint guys, that is the plan. I thought about using gluv it on the bare aluminum then primer and paint, what do you guys think? Also, I have some corrosion pits in there, someone mentioned using a vinegar water mix. Let it sit and then flush the area with water. Then go ahead with the wire wheel. Any suggestions would be great.
bassboy1 said:skinnywaters said:Thanks for the tips on paint guys, that is the plan. I thought about using gluv it on the bare aluminum then primer and paint, what do you guys think? Also, I have some corrosion pits in there, someone mentioned using a vinegar water mix. Let it sit and then flush the area with water. Then go ahead with the wire wheel. Any suggestions would be great.
Vinegar and water should help some. The commercially available products are Zep-a-lume or Alumabrite, but they are fairly dangerous in concentrate form (they are the phosphoric acid PSG mentioned).
The whole goal is to acid etch the metal. The acid starts eating away at what is there. I've heard of folks using just about any acid available, with varying results, so the vinegar, while not as powerful as the commercially available products, will likely yield decent results. With a short soak (10 minutes or so), the acid only gets to the very surface layer, ie the corrosion flowers, and leaves fresh, clean metal underneath.
I personally would use a maroon or brown 3M Scotchbrite disk in a 4" grinder instead of the stainless wire brush. Same concept, but the Scotchbrite will yield a more uniform surface, and be a lot quicker as well.
skinnywaters said:Thats pretty much exactly what I needed to know fellas thanks. Also i do have one place that corroded all the way through, what would be best to seal it. Would marine tex work?
Then once the corrosion is gone do I skim coat the divets with anything? That's where I figured the gluv it would come in handy, its pretty much just like steel flex.
