T-MAN said:Im trying to decide wheather to purchase a regular bow light like the bass pro shops bicolored one or one of those that are on a pole. My trolling motor is bow mounted and i dont know which one would be better. Any advice
rgpemt said:The standard, or my interpretation of the standard is that the navigation lights, red/green must be visible for 112 degrees from the front of the vessel. The white "anchor" light has to be visible 360 degrees. The rules change with the size of your boat. Hope that helps
jellio5 said:My anchor mounts up on the bow so I had to figure something out as well. I ended up going with the "D" cell battery powered bow and stern lights from Walmart....alot less wiring and when I'm fishing during the day I don't need to have them up. I ended up making a little mounting tab out of some flat aluminum from Menards for the bow light takes all of 3 seconds to put each light on and turn them on.
