I know this is long but wanted to be specific as possible. I am mechanically inclined but not so much in the electrical field though I can do basic installation of wiring and have knowledge of how to use a multimeter. Any insight at all would be greatly appreciated. I just want to cover as many bases as possible and perform any tests that I can before getting the boat on the water again. Id hate to get stranded. Thanks in advance.
I got this 14 foot jon boat 2 years ago. I installed 2 deep cycle batteries. One from Autozone and one from BassPro. I do not know the specs on the batteries. The batteries are in the front and have them in sequence meaning wired positive to positive and same with negative from there I have run from one of the batteries 4 gauge wiring to 2 Minn Kota Endura C2 30 trolling motors using 2 - 50 amp 6 gauge quick disconnects at both motors everything is soldered together. I also had a 12 volt percentage gauge at the motors that is removable with crimped connectors and ran a Garmin 4 off this same wire. I have had no issues with the boat and had it out maybe 10 times. On my percentage gauge I never got under 90% running both motors during a 3 - 5 hour fishing trip around the reservoir. During a trip last year I lost a motor in the water but was able to retrieve it. I got it home and thought I had gotten all the water out of it by turning it upside down and letting it air out. This was suggested by Minn Kota. Second to the last trip of the year I noticed that the bearing was noisy so I got a new bearing and installed it and totally dried everything. Last trip of the year had no issues.
Over the winter year I installed a 18 watt led flood light, 12 volt 40 amp rated 4 gang rocker switch box that is fused at each switch, 2 universal 12 volt power outlets, led navigation lights, a removable live well with a timer and using 2 pin waterproof 9 awg electrical connectors in places where I wanted to disconnect items in case they went bad, 12-48 volt kill switch rated at 275 amps, a portable live well with timer on the well(which I have not used as of yet), 16 awg wiring used for wiring accessories. All of the items used were China made from Amazon and all soldered.
On the first trip out this year I noticed right off the bat that my percentage gauge was reading 70% with both motors and by the voltage reading on the Garmin 12 volts the whole time. Never had any issues. I ordered another percentage gauge just like the one I had before thinking it was the gauge. When I got home I put my charger maintainer on the batteries and the reading before charging was 11.5 volts. I had the batteries tested after fully charging and both are ok.
Second trip out right off the bat the percentage was 60% with one one motor and with both 50% and the voltage with both was 11.8 at the Garmin. I carried a new percentage gauge with me and installed it but it read the same. I got out in the middle of the reservoir and everything shut off. I cut the kill switch off then back on and still nothing. I checked the relays to the motors which are 50 amp relays and both had kicked out. I cut off the kill switch reset the relays and had power to everything. So while making my way around on one motor I got to thinking why would everything quit? I can see the motors but why would the rocker panel switch quit? So I decided to try a few things while on the water. I disconnected each motor individually and checked the percentage gauge and both were the same with the rocker panel switch on and off. Each dropped to 70%. When the motors are out of the water both running together or individually the percentage is 90% and I am assuming because there is no resistance from being in the water or pushing the boat. So what ever changes I make or do I will have to test the boat in the water. Does this make sence? I made my way around on one motor but the percentage gauge at the end of the day was 40% but coming in I was into the wind which had picked up considerably sometimes pushing the boat backwards. I got home and put my charger / maintainer on and the battery was at 11.5 and by evening they were fully charged. I decided to wire the kill switch differently thinking this was the only thing that would shut off everything. In doing this I noticed that it had wrote on the switch "ignition protection". Upon inspection of the switch I do not see a "reset" unless it is built in. Either way I swapped the wiring to the motors to where they are not run thru the kill switch as the power and motor are on the inputs side of the switch and the only thing run thru the switch now is the accessories which goes to the rocker switch panel. Garmin, navi lights, flood light, power outlets and live well. I did this in thinking it would rule out a bad kill switch even though it is rated at 275 amps. Next time out I will see if it makes a difference.
