Rob, I really think it makes a difference. I noticed that when I got the lean-pop, I was heading into the wind. The carb is right there, catching the wind, no cover. Look:
But thinking about it, this would be a GREAT way to add HP to a small motor, if you could figure out which bigger jets to use. Force air in (like a supercharger) then add more fuel = VROOM.
But my current jets are sized for the restricted and directed airflow presented by the cowl. Without it, I don't know... Maybe my mind has been poisoned. Over on BBC and on the hull truth, I've read how guys have scored cylinders and blown up motors by running them hard with the cowl and/or baffles off. And if I recall, they commented how much faster they were running... just before they blew.
I doubt if it's a fuel restriction, especially since she ran so hard at WOT. (Maybe a weak fuel pump?) And I really should have known better! The motor was screaming, and I was flying, and a little voice in the back of my head was telling me that something wasn't right. Then I looked at the tach, and it HIT me. DUH!!!!
I just went outside, and she doesn't want to idle for more than a few seconds, before a cough and she dies. I've got a bad feeling about this.
My current plan is to add double oil to the gas, and try to keep her idling for awhile. Sometimes, the extra lube can smooth out very minor stuff in a cylinder, but if it's damaged, it might not come back. If I can get her running well, I'll take her back out on the lake with the double oil and see what happens. THEN I'll check compression. I'll report my findings.
-TH
