thill
Thanks, guys, I guess I'll get some sheet foam and get it under there. Does not look like there has ever been pour foam under there.
Thanks for the confirmation. I have a bunch of sheet foam, and I'm planning to not only put it under the floor, but I might replicate the floatation panels from the later models on either side of the transom.What I found on our '67 was sheets. No poured in foam.
Thanks, Airshot, I'm pretty tickled with them both. Yeah, that green was pervasive in the 70's. Not sure why. I hated that color even back then.Starcraft must have found a good buy on all that ugly green as it was used alot over that time period !! Nice find!
My neighbor had the 16' version. He painted it white and it looked good. For myself, going to keep the ugly seafoam green. After all these years, it has grown on me. Nostalga value.
Yea, maybe "ugly" catches the biggest fish!Maybe that green color attacts fish!
Okay, that is helpful information. The trolling motor I have for it is a 24V so it will need 2 batteries up there, which will help, but knowing they don't like a lot of stern weight puts me a step ahead.We have the 14' model. The front rails had to be an option. My father bought it new off the lot that way. I don't find it tippy. We still have the 3/4 bench, flip-up, driver seat. It was moved back to become part of the rear deck.
You have an open slate over what I did. I'd still go for 4' front and rear decks. Less cuts in the plywood and will still have plenty of floor space.
IMO, don't move the console back toward the stern. Even with max hp motor, they like more weight forward for better planing times.
The gas tank was moved back because the group 29 battery and trolling motor was enough weight forward. It went to the port side to even out my weight over my sons.
I have a Sylvan 16' side console and a 40 hp Merc. With 2 adults and 3 group 31 batteries and gear will just hit 30 mph, but the adjustable trim gives the last 3 mphI got my bolts through the transom and everything is absolutely rock-solid. I'm very pleased with the outcome.
One issue is that the engine pad on the outside is too small for the Evinrude 48 SPL that I've been thinking of using, and this transom has never been drilled. I have a 35 HP Suzuki, a really nice engine that is clamp-on like the original 25, so I need to think it out before proceeding.
Any thoughts out there on how a 35 HP will push a 16 Mariner-V?
