Trinity
Ok, motor is out of the picture. Too much work is needed and it has been in salt water so I am going on the search. Something between 10 and 20hp. Here are a few picture of where I am right now.
mmf said:Looks good but I hope those are not galvanized corner brackets on your framework. Bad news when attaching these to aluminum, chemical reaction and corrosion, also I hope no steel screws anywhere unless stainless. I suppose wood is OK if you are going to keep your boat in the garage or covered, otherwise you will be rebuilding it again in about five years if exposed to a lot of moisture (been there, done that) many times.
webvamp said:I think I'm gonna go with the same paint, Amazon has it for around $17 a qt. How much did it take for your boat?
Rusty
