lckstckn2smknbrls
- Joined
- Oct 5, 2008
- Messages
- 5,043
- Reaction score
- 404
- LOCATION
- Lake in the Hills Illinois
You can convert the motor to use a fuel pump with a newer tank and single fuel line.
lckstckn2smknbrls said:You can convert the motor to use a fuel pump with a newer tank and single fuel line.
It's not an electric pump it is a fuel pump from a newer OMC motor. It's not a hard mod but it does cost a few bucks.Tettle07 said:lckstckn2smknbrls said:You can convert the motor to use a fuel pump with a newer tank and single fuel line.
From what I have read, and at least in Texas, it is against the law to run electric fuel pumps on these type of old motors solely due to the fact that if the line becomes dis-lodged, or you sink the boat, or whatever happens... that electric fuel pump will not shut off and will empty the contents of the tank into the lake... I thought about doing the exact thing and spoke with a GameWarden about it and he told me I would get a ticket everytime a warden saw that set up. So... if you decide to do it... be extra sneaky and hide it well....
On another note any old style tank like that one has a diaphram in it and when you buy that tank if the diaphram has not recently been replaced you need to replace it..... the diaphram costs about $40 and isn't too bad to replace. My $0.02....
Don't use starting fluid it doesn't have any lubricating properties. Just use a spray bottle with the proper fuel oil mix.dtwarrow said:Okay guys maybe I should put this in the motor section but I'm gonna try to get this sucker started this weekend. Have no gas can yet, any help on that is welcome... I'm gonna see if it will start on fluid at least... Gotta be ready by 15th for duck season. Cutting it close...
Have to do the other side camo paint and blind. But the primer and base is done so it should not take more than a few hours to knock them both out... Then wire the headlights and besides the motor, I'm done!
dtwarrow said:Opinions on the winch? New one or just a new strap?
