I recently bought a 77 sylvan 17' boat for a project boat.
The boat has a built in 13 gallon gas tank that looks pretty old. Previous owner said that he filled the gas tank with mixed gas for a 2 stroke before his lower end unit cracked this past fall. I have a newer 2 stroke evinrude that I plan on swapping out with the existing one on the boat. I am worried about the gas that is currently in the tank. Previous owner said that he used non ethanol gas which is good, but I do not know if he put any stabil in at the end of the season.
My question is, to prevent damaging my good motor with potentially bad gas, should I add some stabil or dry gas into the tank?
Or should I drain the gas out into a few external gas cans and then run the gas through a funnel with a gas filter built in (not sure if I can even do this with the gas being mixed with oil)?
I am leaning towards draining the gas from the tank and trying to figure out a way to clean the inside of the gas tank just in case there is any debris in the tank to try and do preventative maintenance.
I may be overthinking this whole thing, but I would like to do whatever I can before the season starts to know that I will be in good shape for this upcoming season. Thanks in advance!
