FuzzyGrub
PATRIOT2 said:This may be after the fact, but I was considering the same thing as far as a battery charger until I found I already have the lighting coil under my flywheel so all I really need is the rectifier assembly ($97 new, looking for used) to be able to charge batteries or operate running lights. You may have the lighting coil already as well.
Coil will not put out enough amps to keep up with a trolling motor, and unregulated can cause problems for some electronics if the voltage climbs too high.
