muskiemike12
If there is an air leak in the fuel line it will cause issues.
MDCrappie said:Ok that's a start. Now you need the tach.[url=https://www.tinboats.net/forum/viewtopic.php?p=315539#p315539 said:MBH » Tue May 21, 2013 7:39 pm[/url]"]Update..
GPS speed is 21 MPH.
And throttle response is very slow from sitting to wot
Since the speed is down (and feel of power loss) the RPM's are likely down also.
Until the tach arrives here is something to try.
With the motor off. Remove the cowling. Have someone advance the throttle while you watch the linkage movement. If shifter is hard to get into gear DO NOT FORCE it, spin the prop just a little. Watch to be sure the carb throttle plate is opening fully. The plate will be horizontal, and level and you should be able to see straight into the carb throat.
Whoopbass said:Since you've had the boat has it ever ran right?
I would get a spark tester and make sure your getting fire on all 3 cylinders.
Whoopbass said:Squeeze the primer bulb until firm then check the carb bowls and make sure they're both full of gas. Do this by removing the drain screws on each bowl.
Is this a 2 or 4 stroke motor?
[url=https://www.tinboats.net/forum/viewtopic.php?p=315832#p315832 said:MBH » Thu May 23, 2013 4:43 pm[/url]"]Whoopbass said:Squeeze the primer bulb until firm then check the carb bowls and make sure they're both full of gas. Do this by removing the drain screws on each bowl.
Top and middle had gas in the bowls.. the bottom carb did not
[url=https://www.tinboats.net/forum/viewtopic.php?p=315372#p315372 said:MBH » Mon May 20, 2013 1:37 pm[/url]"] I did have the carbs rebuilt and the timing was off so that's fixed now.
[url=https://www.tinboats.net/forum/viewtopic.php?p=315874#p315874 said:turbotodd » Thu May 23, 2013 10:32 pm[/url]"] In a test tank, pull a plug wire and then start it. Listen to it. Shut it off and then pull one of the others. If you have a dead cylinder, or even a carb that's not feeding it properly, you'll find out which one real quick.
[url=https://www.tinboats.net/forum/viewtopic.php?p=315909#p315909 said:MBH » Fri May 24, 2013 7:30 am[/url]"]So dont even run it like this? I dont mix the gas as it had its oil injected
[url=https://www.tinboats.net/forum/viewtopic.php?p=315918#p315918 said:MBH » Fri May 24, 2013 8:34 am[/url]"]10-4.. I'm tempted to try to tackle it myself
MDCrappie said:[url=https://www.tinboats.net/forum/viewtopic.php?p=315918#p315918 said:MBH » Fri May 24, 2013 8:34 am[/url]"]10-4.. I'm tempted to try to tackle it myself
|Pull the line off feeding that carb and squeeze the primer bulb to see if fuel comes out. If it does then the blockage is in the carb, if it doesn't then the blockage is in the feed line.
If blockage is in carb, I would remove, clean and check float adjustment.
