tonynoriega
So I can see on the forecast that the weather will be a bit warm for 3 to 4 days...
Was thinking that if the highs reach 70+ I might get my rig ready to paint...
My question is... Should I paint the inside or outside first?
I was originally thinking the outside first because it seems to be fairly straight forward....both sides, and the transom.
Hit it with 2 to 3 coats and let it cure for a few weeks.
Then the inside second mainly because it has a few tricky angles that will require some creativeness... and I have some non skid to address as well.
All of the benches are removed, so I can whip those out pretty quick.
Then start putting it back together with all those SS nuts and bolts...
Does that sound like a decent plan? Outside then inside?
