[url=https://www.tinboats.net/forum/viewtopic.php?p=343350#p343350 said:
Clint KY » 02 Mar 2014, 10:08[/url]"]I have a 1648 with a large front deck with foam floatation under it. I want to mount a pedestal seat on that deck that I can remove so I can retain the use of the deck while fly-fishing. I have looked at the standard Pin type Steel Base Plate but am at a loss on how to mount one. I have seen Nutserts that I can probably find someone locally who has the insertion tool, but don’t think the thin aluminum alone will support the weight of me if I were to lean over a bit. Anyone have an idea or suggestion on how to do this?
This is a pretty easy project to do.
Your concerns for the small base plate and thin aluminum decking are well founded, an installation of the pin type base plate fastened directly to the decking wouldn't last long... especially with only 6 fasteners securing it to the thin aluminum decking.
Pedestal seat bases are primarily designed to be fastened to a plywood deck, and that's what I'd do. You can either deck your entire front deck with plywood or make a larger base out of plywood for the pedestal base to fasten to.
Option A:
For a clean flush installation I would cut a piece of 3/4" plywood the size of the front deck and fasten the pedestal base to the plywood with stainless steel 1/4-20 bolts and T-nuts:
If you use 3/4" plywood with a 1/4" thick pedestal base a 1" long bolt should come out flush with the bottom of the decking, if the bolts protrude below the decking you can mark them and cut them off.
After you get the ped base installed on the plywood, remove it and lay the decking in the boat and mark and cut the hole for the center pin in the aluminum decking. Secure the plywood decking in the boat with rivets or screws preferably through your deck framing members and reinstall the pedestal base.
Option B:
This uses a smaller piece of plywood, a 16"x16" or maybe even a 12"x12" piece (the bigger the better though). Secure the pedestal base to the plywood and the plywood to the deck in the same manner described above. The larger plywood base will distribute the weight and forces of someone sitting in the seat over a larger area and you'll be able to secure the plywood to the boat with more than just 6 fasteners, I suggest fasteners installed around the perimeter on at least 3" centers or closer.
Of course you'll want to seal and protect your plywood with either installation, I suggest using a non-slip paint the same color as your boat.
If you choose option B you'll want to bevel the edges of your plywood on a 45 degree angle.
