[url=https://www.tinboats.net/forum/viewtopic.php?p=328292#p328292 said:crankbait09 » 14 minutes ago[/url]"][url=https://www.tinboats.net/forum/viewtopic.php?p=328270#p328270 said:shawnfish » Today, 11:02[/url]"]your flywheel will come right off with the puller or it is gonna give you a good fight. DONT FORGET TO USE GRADE 8 BOLTS
don't forget to loosen the flywheel nut about one turn so the fly has room to pop off, don't take the nut all the way off because the flywheel could fly off and knock your teeth out.
if you get the puller on and tighten real good and it don't pop off spray some 3 in one or some wd-40 under and around the nut so it can work down the shaft. after a few minutes give it a few taps with a hammer but use a chunk of wood so your not directly tapping the fly with the hammer. good taps just don't hit it hard. if that don't work soak it again and tighten the puller some more and wait an hour or a while and repeat above process. mine took almost 2 days to come off.....the condensors and points are cheap so you may as well replace them too.....
sentence in red...what do I need to use grade 8 bolts for?
do I NEED to remove the magneto yet? I only need to remove this when I'm ready to replace coils, right?
what do you need grade 8 bolts for?? unless you know a trick to get underneath the flywheel without removing it. all that stuff is under the flywheel. you are going to need the flywheel puller with 3 GRADE 8 bolts 1/4 inch I believe. MUST BE GRADE 8 anything less could (WILL!!) break of in the flywheel and then its never coming off. GRADE 8 BOLTS do you have a service manual? is it a factory manual?
