Very nice build. I just picked up a Mirrorcraft 14 Deep Fisherman that I plan to work on a bit and trick out for a fishing/hunting rig. One question I have regarding your build is: When you filled the below deck sections with floatation, are you concerned that water might get trapped between the foam and the aluminum hull eventually causing the aluminum to breakdown and create pin-holes in the hull? I understand the need for the flotation, but are thinking space should have been left so that water cannot get trapped between the flotation foam and hull.
Thanks.
