Prop Spin
You should have taken some advise from a few us here can checked your set up before you went and re-hubbed a prop that probably was ok. #-o
Luckly the prop was bad as well. Theguy at the prop shop showed me the old hub an it was shredded pretty good.
A variable was eliminated that could have caused problems later on. What would really stink would be ,being miles from the ramp with a spun hub. I've been there and its no fun at all. :cry:
Amen to that, I was able to cruise at low rpms maybe about 3 miles per hour, It would only spin when your get on the throttle to really take off. But i have since found a long shaft 25hp that I'm excited about. going this weekend to hopefully take for a test ride. :D
