prop
Spun hub, motor mounted too high, too much trim, ventilation plugs that are too large (if so equipped)
ok i gooogled spun hub my pro has about half a turn then tight can t turn prop while holding flywheel does a little free turn not even half though do i need a new prop
Hard to say without seeing it.
I wouldn't discount the spun hub. There is a lot more force being applied to that area at WOT than what you are putting on it by hand. I have one with a spun hub that I really have to pry down on by hand to make it slip but you can't run it on the motor above 1/4 throttle before it slips.
thanks for the help took to local prop shop they said i have a spun hud thrity buck yea fishing saturday
