I have a short transom and a long shaft motor. I installed a Mini Jacker but even with it mounted 2" above transom and a 3/4" block under the motor it still sits too low. Motor is a 9.9 Merc Bigfoot and I topped out at a blazing 7mph yesterday. Motor needs to be raised at least another 2". My idea for raising the motor is to remove the Mini Jacker and use the holes with some aluminum angle inside and out sandwiching a board across the top of the transom. This would also keep waves from splashing over the transom. Good idea or bad idea?
