swmohunter
- Joined
- Dec 20, 2009
- Messages
- 5
- Reaction score
- 0
First I would like to say, please excuse my ignorance.
I have a 1973 Evinrude 25hp model 25353 tiller steer. I would like to start by saying before I changed the ignition switch, the motor had not been giving me any trouble getting started (except once in frigid weather).
I had to replace the ignition switch the other day due to the key breaking off in the ignition. (Here is where the ignorant part comes in) I tried to replace it with an auto ignition switch. I found out after trying to start the motor several times that I needed a marine ignition switch. I have since replaced it with a marine ignition switch (same make/model as the one that was working to begin with) and am certain that I have the wires connected correctly.
The motor will turn over just fine but it will not fire.
My question would be, could I have burnt up, shorted out, or destroyed any parts while using the auto ignition? If so, where would I need to start as far as looking for what damage I may have caused?
As you can tell, I am new to marine problem solving.
I also know that I need a manual and have one coming. What better way to learn than to learn by making mistakes, right?
Thank you for any help you may be able to give me.
Nathan
Nathan
