Tinhead1986
- Joined
- May 23, 2023
- Messages
- 45
- Reaction score
- LOCATION
- Orangeville Ontario,Canada
I’m replacing the Transom in my 14 ft MirroCraft and i’ve just found a crack at the bottom of one of the holes where the bolts go through to bolt the transom to back of the boat inside the hull . Looks like the last owners over tightened the bolts and now there’s a crack at one of the bolt holes. How should i fix this the crack goes all the way through the back aluminum skin . I was thinking of drilling a small hole at the bottom of the crack to stop it from spreading and sandwiching checker plate with 4200 or 5200 to the back with closed end rivets
Also in the near future i’m putting in a check plate floor . is it a good idea to drill through the side of the hull to add Aluminium angle brackets for the floor framing. I’m worried with how much a boat flex’s that i will have problems with rivets tearing through the side of the hull . Should i do that and can I use closed end rivets
