russ010
good catch waterwings... but for some reason, I can only see 8 holes in your drawing... #-o
jirwin6985 said:Brine the boat looks great so far. As far as plumbing the live well again. If you are going to reinstall it i would drill out the current holes to the size of a thru hull fitting and replum the hole thing. https://www.basspro.com/webapp/wcs/stores/servlet/Product_10151_-1_10001_8029?cm_mmc=froogle-_-225-3-5-_--1-_-38-502-364-00&hvarAID=froogle&mr:trackingCode=FD957E21-11EB-DD11-80C2-001422107090&mr:referralID=NA
Something like that. That way you dont have to worry about the old fiting leaking. If you have more questions Id be more than happy to explain more in depth. Are you looking to use the livewell it sounds like you arent sure whether you want to install it again or not.
Joe
Brine said:Also, where do I buy that black stripping to go aournd the opening of the livewell?
Does anyone have a better solution?
Thanks.
They do that because they are too lazy to walk to the back. Not really. :lol:Brine said:Thanks again Russ, that looks good.
Does anyone know how to best split the weight in the boat for max hull speed? The electric only guys always stand at the front of their boats when making runs I assume to the back of the boat as high as possible. Figured I would ask before I start planning out battery placement.
Leaving a 2 - 3 inch lip around it would be adequate, and the divider in the middle would be all that much better. Plus, two separate hatches are great for organization's sake.Brine said:If I don't mount the pedestal on top of the bench, would it be ok to cut out the entire top of the bench? maybe leaving a 3" lip around the whole thing? The bench is 56" long at the top, 42" at the bottom, and 20" wide. I'm wondering if I should leave some meat in the middle (have 2 cutouts instead of 1) for some rigidity.
Whaddaya think?
