dyeguy1212
looks good
Nussy said:What is that you put on the floor? Is that some sort of epoxy?
dyeguy1212 said:By saying that you "self etched" the steelflex, does that mean you put self etching primer on it? Seems like a bad idea, considering self etching primer is meant to bond to metal. Then again, the paint on top of the primer bonds to it fine... (head explodes)
YesTroutman3000 said:good to know that you can paint that stuff...
How much did you mix at a time? Not real sure. I used two plastic spoons; something that you would serve punch with. I tried to use a measuring cup but it gets real messy and then you can't read your measurements
How much did you use? almost the entire thing but I still have a little left. How many coats? Two; I was really light on the first coat but the second was so thick it felt like spreading concrete.
Did you use a normal foam roller from HD or Lowes.
