Re horse stall...you may have the real answer!! Ha Ha. richg99
Darn and it said "Waterproof". Well, then if this one does as you say, then I'll put it in the Portable Garage, I'm getting from HF this next month as a flooring then figure a different way of doing the boat floor.looserivet said:I'd be cautious of that EVA foam mat material. We have both EVA and PVC foam mats at work around every work station, they made the mistake of taking a few of them outside to clean with a hose and they held water like a sponge. Its also available by the roll from most floor covering stores and Home Depot, its sold as carpet runner. Some of what we have are small 'fatigue' type mats, others are cut from bulk rolls. While its not really slippery when wet, it does absorb water like a sponge. When I went to life a 4x8' piece of mat that sat out on the curb for a week it felt like it weighed a hundred pounds or more.
Yep, the TS here has a pallet stack of these sitting outside the door.. Way to heavy for my little ol' 12 ftr. Thanks for the heads up..looserivet said:The barn stall or 'Cow' mats that I'm used to seeing are made from recycled tires and are usually 1" thick. Most come in 5x10 or so sizes but they're super heavy.
They sell various sizes at Tractor Supply here, I'd say a full mat is over 80lbs, probably more.
Darn and it said "Waterproof". Well, then if this one does as you say, then I'll put it in the Portable Garage, I'm getting from HF this next month as a flooring then figure a different way of doing the boat floor.Y_J said:looserivet said:I'd be cautious of that EVA foam mat material. We have both EVA and PVC foam mats at work around every work station, they made the mistake of taking a few of them outside to clean with a hose and they held water like a sponge. Its also available by the roll from most floor covering stores and Home Depot, its sold as carpet runner. Some of what we have are small 'fatigue' type mats, others are cut from bulk rolls. While its not really slippery when wet, it does absorb water like a sponge. When I went to life a 4x8' piece of mat that sat out on the curb for a week it felt like it weighed a hundred pounds or more.
