Andy Taylor
Where's a good place to buy the chains already made up with the hooks on each end? What is the recommended way to figure out what length you need? Thanks
Andy Taylor said:Where's a good place to buy the chains already made up with the hooks on each end? What is the recommended way to figure out what length you need? Thanks
Buddychrist said:Attach your trailer to your vehicle and then back it up until your trailer is two inches away from hitting and then cut the chains to be tight at that angle.Andy Taylor said:Where's a good place to buy the chains already made up with the hooks on each end? What is the recommended way to figure out what length you need? Thanks
You want to put your trailer and tow vehicle into the jack knife position then set the chains for the proper length.Andy Taylor said:Buddychrist said:Attach your trailer to your vehicle and then back it up until your trailer is two inches away from hitting and then cut the chains to be tight at that angle.Andy Taylor said:Where's a good place to buy the chains already made up with the hooks on each end? What is the recommended way to figure out what length you need? Thanks
Thanks, but I don't know what you mean.
