bigwave said:How does the boat set in the water? Is it stern heavy? If so, I would consider the pods. I like the idea of moving the battery forward.....if you can leave the fuel aft, it is safer to separate the two. You boat is very functional for gigging.....I say you put a small center console in and maybe a good fishbox/livewell since you use for commercial. If you plan on putting a larger motor you will probably be reaching the limits of the hull.......If you need the speed I would get a larger boat that can handle the appropriate engine. Just my thoughts, you did a great job so far. =D> =D> Hey Dave he called you a pro..... #-o
stevesecotec02 said:When u added the hatches in the stearn did u have to remove foam from that area?
