minicuda said:
I'm very interested in how this goes. I have often wanted a solar charger for when we boat camp. Every summer we go kokanee fishing for 5 days by the 3rd day both my trolling batts are toast. If I could find or build a solar charger that would charge a large deep cycle in 8 hours I'd be good to go. It wouldn't be on the boat it would stay at camp and I could leave a batt on it all day.
I wouldn't like to discourage a person trying, but charging in 8 hours via solar panels is difficult and expensive. The original poster's $49 solar panel will take 8 straight sunny days to fully charge a deep cycle battery. You would need to wire several (more than a dozen) of them in parallel (and probably in series as well) just to get the charging completed in less than a few days. And that is under optimal conditions with perfect sunlight. Often something like 80% of the sunlight will result in less than 50% of a charge. So you'll be waiting many days......
A second $50-$60 deep cycle battery will get you much, much farther (or even a third, fourth battery). Of course, as a solar experiment, as long as you have the money and time to attempt such an endeavor, it could be worth trying. But you won't be doing much fishing.
If one is serious about solar charging, I'd suggest trying something easier first (like charging a AA rechargeable nickel metal hydride battery). Spend a little money before you spend a lot. Get the hang of how the charger works, and what its limitations are. After that, if you're not concerned about how much money you're going to spend, take on the challenge of creating a charger for a high amperage deep cycle battery.
